BOOTP.Client.RxReply
Description
This message can be used to trace all incomming BOOTP/DHCP packets for the DHCP Client module.
Remedy
This is for debug purposes and should only be enabled on request of Extreme Networks technical support.
Severity
Debug-Summary
Message Text
Received DHCP/BOOTP reply on vlan instance %vlan%, from %srvIP%, type %opcode%, length %len%.
Message Parameters
Name Type
vlan uInt32
opcode uInt
len uInt
srvIP IP
